Forgot to post this last oil change. I used a AC Delco UPF44 oil filter on my 5.3 chevy. I pre fill the oil filter before I install it. I usually don't spill any oil and get it all in the filter but this time oil got into the metal plate and filled the area right under the black gasket. Then air bubles started to come up through where the metal plate meets the rubber gasket as if the metal seem has a leak and oil was getting into that part. I hopr I explained that clear engough. I don't know if that is good/bad or normal.
So far oil pressure seems normal but ever sence I started using German Castrol and UPF 44 my enfine knocks a lot on hot start ups. It never did this on Mobil 1 and Napa Gold oil filters. I did Use Mobil 1 and a UPF44 once befor using GC and the engine was quiet. I think the engine noise is caused bu the GC over the oil filter???
