Originally Posted By: muffinstew
After reading this thread, I started thinking about how my Honda CBR600F1 would react if I started using a straight 40 weight oil? Reson for this thought is becuase the majority of used oil analysis I read from the motorcycle UOA section all shear out of grade very fast. My bike is only ridden in the spring/summer/fall months and the coldest start it may ever see is 55-60 degrees F. I wonder if a straight 40 weight will hold up well to a transmission that is capable of spinning 12,000+ RPMs? Would there be any reasons not to run a single weight oil in a 4 cylinder sportbike?
The multi-grades shear down quickly presumably because of the meshing gears. Mono-grade oil doesn't have any VII polymers to shear, so it stays in grade. Mono-grades provide better operating temperature lubrication since there's no VII polymer taking the place of oil.
Only downside to mono-grade oils is cylinder wall lubrication immediatly following a cold start. Cylinder walls depend on throw-off from the connecting rod bearings. While the oil's cold or cool, not as much is thrown to the cylinder walls, BUT, that which is thrown is a thicker film so there's some compensation. Keeping rpm's down for the first several minutes of operation are key to minimizing wear at start-up.
Cams LOVE thick oil, the thicker the better. The rod bearings will retain enough oil regardless of viscosity that cold starts are not an issue for the rod bearings. It's when everything's heated up that the thicker oil provides a better film of metal protecting oil.
To your specific question, if you're riding every day (lots of cold starts), and presumably don't ride all that far, using a SAE-30 in your temperatures would probably be better. Also, since your engine spins faster, you'll get better hydrodynamic lubrication from SAE-30 in your engine than I would in mine with a SAE-30. If your temps aren't well into the 90's during your riding season, use SAE-30.
My temps are much the same, but I stick use the SAE-40 for it's superior high temp lubrication and over-do the whole thing by pre-heating the engine with a 100-watt light bulb overnight before I take it out for a ride since I seldom ride more than once a week, and always ride a minimum of 120 miles when I do.
Another aside on SAE-30. I use 10w30 in my car in the winter, then switch to SAE-30 in the warmer months. The engine will eat 1 to 1-1/2 quarts between 7500-mile OCI but will consume less than 1/2 quart when using the SAE-30 even in the hotter weather.
Regards, Gary in Sandy Eggo
