Originally Posted By: BrocLuno
Originally Posted By: 1JZ_E46
That’s because it’s only used by lawnmowers these days. Your average 10W-30 will outperform straight 30 across the board.
Not even close. Straight SAE 30 HD will prolly blow the multi's cylinder wall wear number out of the water. As long as you don't have to worry about cold weather starts, straight grades are almost always better.
Now somebody like Redline who sells to multiple markets rates their straight grade racing oils as multi's for the street crowd. But in many applications straight grades do really well.
Straight grades are the preferred for seriously expensive engines like Ships engines where an overhaul is $100,000 if it's an penny. They are quite common in marine and in light aviation. Drop by most small airport lube shops and there are lots of straight grade choices.
These applications do not like VII's of any kind ...
The closest generally avialble multi might be something like Delo 400 15W-30 SD (severe duty) with minimal VII's added.
But you can get SAE straight grades at most tractor shops, Farm & Fleet stores, etc.
Then why did the industry move away from straight 30? Straight 30 sounds good for sustained use applications (marine/industrial), not engines that cold-start every morning and have multiple on/off events during the day (passenger cars).
