It’s my mom’s car quick lune had stripped the drain bolt and was leaking so. I just changed the oil and put a new plug in.Nice thanks for sharing. Why such low mileage?
Good Morning jxthomps,It’s my mom’s car quick lune had stripped the drain bolt and was leaking so. I just changed the oil and put a new plug in.
They are junk drain plugs. Mine rounded over with a 6 point. Thing was very mild steel. @Al thought I wasn't careful enough when this issue was presented on subaruforester.org ages ago.Unbelievable.
All I can to that, wow.They are junk drain plugs. Mine rounded over with a 6 point.....
Filter looks ok. Don't see coo but assuming China as doesn't look like a Champ Labs made filter. Recycling oil at AZ recently checked out STP filters. Standard blue can like topic, China coo. Otoh, XL is Champ Labs, very similar to or same as Super Tech MP series, with orange silicone adbv.
Yeah, lousy about the drain bolt. Rounded the bolt and leaking on top of it. smh Assuming threads still ok and new drain plug and crush washer fixed issue?
Thanks for c&p.
Edit, Just looking closer don't see an adbv in pics. Did it have one and just not seen/shown
Thanks for c&p.
Edit, Just looking closer don't see an adbv in pics. Did it have one and just not seen/shown?
Thanks for c&p.
Thanks for C&P!
Also interested in build of the filter. Does the center tube have holes, louvers or e-core?
Base plate does not look like Champ / Fram?
Yea drive a 2017 Outback I have done all the oil changes on it and I have had to get a new plug also.They are junk drain plugs. Mine rounded over with a 6 point. Thing was very mild steel. @Al thought I wasn't careful enough when this issue was presented on subaruforester.org ages ago.
Nope. It is a Junk Part for the New FB2.5 release 14mm hex head. They went back to 17mm headed bolt with model refresh.
Tried to get a free one from Subaru but the parts guy said no.
Hope the OP got some $$ back.
here is mine
