If you're going to mix, mix within brands. Will mixing brands hurt? No, CATERHAM makes a good point: when you change your oil and switch brands, you are in a sense mixing brands with the remaining old oil in the sump. That doesn't hurt anything, but if you are mixing with the intent of tweaking viscosity, I'd stick with the same brand. Having said that, the last year or two of oil changes for my beater Aerostar I tossed all the widow and orphan qts. I had laying around in it. Aside from the oil pan rotting from the outside in, no problems to report. lol
