Originally Posted By: poiuy223
seems like if your car is spec'd to use 5w30, might as well run 0w-40.
No. A 0w-40 is a Euro oil with relatively high HT/HS. If you run it, you might just take a hit on fuel economy without gaining anything in return. If your engine was designed for 5w30, then that's all the protection you need.
But I am generalizing here a little. There are non-energy conserving 5w30 oils out there, too, with relatively high HT/HS (such as BMW High Performance oil made by Castrol). So, focusing on the SAE grade isn't always the correct approach. Rather, focus on other specs required by the engine mfg.
