Hi All,
I have a Toro 20007 mower with a Tecumseh LV195E engine. I started noticing missfires and then a gasoline smell in the oil.
It's been running with fresh SAE 30W oil since May and fresh gas with STA-BIL. Spark plug and filter were both changed in may as well.
Person at the mower shop suggested that the a carb cleaning/replacement part kit would probably clear it up. Had this done and it does the same. Then I started thinking possible sheared flyweheel key because when I sharpened my blade in May, it almost came off because I didn't torque it down tight enough (I've not hit anything that would cause the key to shear).
Mower shop suggested I bring it back up when I said it was still missfiring after the carb tune up. I ran my theory of the flywheel key by the mechanic and he said it did sound like the timing was off.
Called today asking about my mower and the mechanic came on and said that the flywheel key was fine and that they went through the carb again and all checked out. He said the missfires were "Nothing to worry about". When I picked it up he said that if you start looking into valve replacements you're getting in the 200+ dollar range and I won't put any more $ into this mower as it's from 2007.
Although my first batch of gas this season had STA-BIL, I put Sea Foam my second can that I filled up a couple weeks ago.
So based on what the mechanic said, about the flywheel and carb checking out, is it possibly that Sea Foam may correct this after running it through the engine for a month or so? Or am I looking at living with these missfires until this think dies?
Any suggestions are welcomed. I'm not afraid to get my hands dirty on this, the only reason I had them do the carb tune is because I had a lot going on and had never done it before so I figured let a pro do it.
