Stay away from Low SAP oils?
WA
I been pondering what oil I should use in my 2010 VW GTI 2.0T DI engine. I have a Napa down the street that stocks Lubro Moly oils. I also have a VW parts shop within walking distance of my house. They stock Pentosin and Total oils.
I know I should be looking for a low volatility oil to help fight intake valve deposits. I would love to use Redline 5W-40, but I will stick with a VW 502 during the warranty period. I will be doing all my oil changes myself. Three free oil changes from VW isn't going to change my mind about VW Service. My wallet can handle the expense just find! I will be doing 6 month OCI's. I drive 90% city, 4.2 miles to work.
Here are some of the oils I can find locally.
Lubro Moly Synthoil Preminum 5W-40 Group III
It meets VW 502/505 sepc
MB 229.3
BMW LL-98
Lubro Moly 0W-40 Group IV
It meets VW 502/505 spec
MB 229.3
BMW LL-98
Pento High Performance II 5W-40 Group III
It meets VW spec 502/505/505.1
MB 229.51
BMW LL-04
Porsche
Total Quartz Energy 9000 5W-40 Group III
MB 229.3
BMW LL-01
Porsche
The Pentosin oil meets more current specs, but it's a low SAP oil. Will this oil with it's lower amounts of SAP still be good in a non diesel engine? I think BMW warns about using a LL-04 spec oil in a Petrol engine car?
I know I can go down to Autozone or Walmart and pick up Mobil 1 0W-40 or GC. I tried those in the past with my old VW's. I'm looking to try something new this time.
Thanks
I would avoid oils that contain Mg compounds as soot dispersant in a petrol engine as they are the most abrasive of the adds and add more EP surface competition than is necessary in non-diesel applications.
The Pento High Performance II meets BMW LL-04 and MB 229.51 specs. These are low SAP specs.
How about an OC special at PepBoys w/Mobil 1 ESP 5w30?
I don't see how dry intake valves are affected by sump oil volitility.
Did you even read my post? I didn't say I wanted to use a 507 spec oil in my GTI. I was asking if they're any ill effects of using a low SAP oil in a non diesel engine.
A lower volatility oil will help Blow-by in a direct injection engine.
Besides no Pep Boys in Oregon....
Mobil 1 ESP 5w30 is recommended for VW 502
Mobil 1 ESP Formula 5w30 meets or exceeds the requirements of the following industry specifications:
ACEA C2, C3
ACEA A3/B3, A3/B4
API SM/SL
API CF
Mobil 1 ESP Formula 5w30 has the following builder approvals:
BMW Longlife 04
Mercedes-Benz MB-Approval 229.31 and 229.51
Volkswagen (Gasoline/Diesel) 504 00 / 507 00
Porsche C30
PSA B712290
PSA D - Level 3
PSA E - Level 3
AvtoVAZ Group “Luxe”
Chrysler MS-11106
AAE Standard STO-003-05, Group B6
Also recommended for use in applications requiring:
JASO DL 1-08
Volkswagen (Gasoline) 502 00 / 503 00 / 503 01
Volkswagen* (Diesel) 505 01/ 505 00 / 506 00 / 506 01
MB 229.3
BMW LL-98
MB 229.3
BMW LL-98
MB 229.51
BMW LL-04
Porsche
MB 229.3
BMW LL-01
Porsche
Thanks
I can't give you a good reason why other than reputation of the brand, but out of the oils you listed and especially since it is within walking distance, I would give the Total a try.
Lubro Moly Synthoil Energy 0W-40 is also Porsche-approved by the way. That would be my recommendation.
