I've noticed some people have questioned the accuracy of some oil analysis labs. However, Polaris Labs is one of those which is considered accurate and much is made about their ISO 17025 A2LA accreditation. So, recently I registered my 2011 Ford Fusion with them, including the fact that I planned to use Amsoil Signature 0W-20 oil in this vehicle.
A few days ago, I sent them three samples of oil for virgin oil analysis. The oils were:
- Castrol Edge Titanium 5W-20 SN/GF-5
- Mobil 1 Extended Performance 5W-20 SM/GF-4
- Amsoil Signature 0W-20 (ASM) SN/GF-5
All three samples were from new, unopened bottles which were shaken well prior to pouring the samples directly into the sample bottles. On the sample submission form, in the space marked "Notes to Analyst", I noted that each sample was virgin oil and the brand and viscosity information.
Today, I received the following report back:
There is so much wrong with this report, I hardly know where to start.
First, the analyst treated all three samples as if they were Amsoil 0w30 in spite of the fact that all three were clearly labeled as 20 weight oils and in spite of the fact that I registered this vehicle as using 20 weight oil.
Treating these oils as 30 weight led the analyst to flag two of them as low viscosity. What's even worse is that the sample with the lowest viscosity was NOT flagged as low viscosity.
The samples were flagged for additive levels different than expected for Amsoil 0W-30, BUT NO ONE THOUGHT TO LOOK AT THE "NOTES TO ANALYST!"
All three samples had significant iron levels. On virgin oil. Really? Really???
All three samples had contamination with silicon and sodium. On virgin oil. Really? Really???
All three samples had between .3 and .4% fuel dilution. On virgin oil. Really? Really???
All three samples had significant levels of oxidation and nitration. On virgin oil. Really? Really???
I'm not even going to try to figure out which sample is which. This report is so bogus that I don't believe any of it.
Needless to say, I'll not be sending any more samples to the Indianapolis Polaris Lab.
