5w20 Honda Canada
New Brunswick Canada
This is a VOA on 5w20 Honda Canada oil.I beleive the oil is made by Petro Canada
Molybdenum 43
Boron 50
Silicon 7
Sodium 1
Calcium 1690
Magnesium 2
Phophorus 836
Zinc 924
All other levels were 0
Flashpoint 445
Viscosity @210f 55.2
DAVID: The only unusual finding in this sample of virgin 5w20 oil is the silicon, at 7 ppm. That's a little high for a virgin oil, but it could just as easily be an additive (anti-foam) as a contaminate. No moisture or insolubles were present in the oil, and the viscosity was normal for a 5w20. The TBN of this oil read 9.5, which is standard for a gasoline-use engine oil.
Definitely way different than the US Honda 5w20. It's viscosity is 8.94cst at 100c, so it's a high 20wt, however the US Honda sample was a 30wt (although I still think it must've been some sort of packaging error and 5w30 was put into a 5w20 bottle)
The 7ppm of silicon is not usual, both Schaeffer oil and Redline usually test out to 7-10ppm of silicon on VOAs too. Once you run it for a bit, this silicon depletes but then is replaced by silicon from dirt. So if you start out at 7 you could very well end up with less by the end of your interval, if your air filtration is good.
[ February 12, 2003, 08:03 PM: Message edited by: Patman ]
