Don't worry, I did not take it that way. I just have gotten alot advice from guys have never owned an old tech V8 like mine.
I do agree with you on the start up. When I tried delo 15w40, motor spunn alot easier. The reasons I was uneasy about the 15w40 were several things.
When hot my rockers were alot noisier. Also, my Holley, which is tuned about as good as one can get still runs a little rich and with the overlap on my cam I worry about fuel dilution. This is another reason I run the 20w50. And lastly, this may just be in my head but, the car seems to have more power with the thicker oil. I don't know maybe it seals my rings better for better compression. He he.
Now, I will tell you this. I have played around with some 20w50's and some are a little thicker than others. I used to run Valvoline Racing 20w50 but quit because it was so thick, like honey. The Havoline is a bit thinner and flows a little better. The RP upon observance seemed thick like the Valvoline Racing.
After I fix the front seal on my trans. I will probably go back to the Havoline. I know I probably think to much and believe it or not, I would really like to use a 15w40 but I'm not sure its right for this particular motor. Any thoughts
Blazer.
