I'm also thinking I might get another induction single burner cooktop to set on my smooth top stove.
I had one once and I kind of miss it.
What would that accomplish?
I am fairly new to cast iron but I now have 3 lodge pans. There good pans, but I have spent hours sanding and polishing to a decent finish, then several more cycles of seasoning to get them closer to non stick. So if you want to cook an egg in a lodge pan be prepared to invest several hours and plenty of elbow grease into finishing the pan.
You can purchase ones that are already smooth, but there much more money - https://backcountryiron.com/products/10-inch-wasatch-smooth-cast-iron-skilletThanks for the warning. I guess I don't want to get into something like that.
If I have to though I may get a new 8" SS fry pan.
Or leave it in the shell and soft boil or poachThe only way eggs don’t stick to cast iron or SS is with a lot of grease.
That always works.Or leave it in the shell and soft boil or poach
Same affect I guess of grinding a cheap lodge down yourself, without the work.
Not healthy.good luck + ditto on bacon grease a HEALTHY SATURATED fat that tastes great!! just ordered my favorite bacon from Bergers their thick cut bacon steak!!
I have 3 cheap lodge pans. In factory trim they will not fry an egg without sticking - the rough surface is the issue. Like I said, I have polished mine down to a smooth finish and re seasoned, but your talking about a 2 - 3 hours of work total.
Cold eggs room temp directly from under the hens don’t matter hot pan warm pan don’t matter. Hand flipped I haven’t used a utensil to flip in years never a need.
I wish you luck you want them to work you gotta float them on oil. I’ve been down this rabbit hole before and one day you get lucky next time *** I did the same thin. I know what works day after day after day no matter what the conditions are. Again you want it to work float them in oil.Yes but pan and egg temperatures do matter when using SS or CI, which, in case you forgot,
is what I intended this post to be about, not non stick pans.
What kind of skillet is that anyway?Same skillet I run ever day for my eggs they are dang good I never need utensils just hand flip perfect every time.View attachment 134319
https://www.calphalon.com/cookware/...inch-and-10-inch-frying-pans/SAP_2172317.htmlWhat kind of skillet is that anyway?
