Going to be needing some winters for my 1993 mr2 here soon. I will need wheels too.
The car currently has 16x7.5s on it with a 225/50 in the back and a 205/45 in the front. Hankook Ventus V2 Concept2 tires.
I would like to run a staggered winter setup as well. Probably something in the 15" range but those tires are harder and harder to find in smaller sidewalls like a 50. I believe I can fit most 14" wheels over my front brakes so that is an option as well.
What wheel widths do you think I should go with to ensure a decent ride and tire selection? Maybe 15x6.5 all around? My issue is that I cannot run anything bigger than a 50 series sidewall up front with the 15" wheel in order to not rub the spring perch and there are no winters available in sizes that seem to fit.
What should I do?
What should I do?
