st with mos2 or pup
Hi should I use supertech with liquid moly mos2 or Pennzoil ultra platinum, I will do 4.5k oci using subaru oem oil filter, it both comes out to 30$ for the oil and I would like to know what I should use. Thanks
St and mos2 is my vote.
That stuff is great for your timing chains and rings.
Are you attempting to correct a problem of some sort by using the additive?
What vehicle is this? What does your owner’s manual say about additives?
