Owen Lucas
$100 Site Donor 2023
- Joined
- Sep 5, 2021
- Messages
- 4,975
Is there a troublemaker in your neighborhood?Got a fancy vandal proof mailbox to do in green also.
That is the bomb
I only hand raked and put down pre emergent so far lawn is still sleeping
I'm in SW Ohio and could have mowed 2-3 weeks ago but I always think "let it grow out and thicken plenty before the 1st mow". Of course it's always much longer than I think by then so I have to make multiple passes to get rid of the clumps. I should probably not do the back-and-forth pattern when it's really though, but I try to get stripes![]()
I don't have mulching blades, well, unless the stock blades do some mulching. I have a small, 36" Hustler zero-turn (fits through our gate) and I have to run it with the discharge 'shield' pulled up out of the way. I don't think it has enough power to throw the grass that well with it down in the normal position. I also have the deck height with a spacer (okay, it's really just a thick nut) to get a little add'l height beyond the 4" or 4-1/2" max height (can't remember which it is).I usually leave my mulching blades on for the first couple mows, I just take the block-off cover off. It's quite clumpy, especially the backyard due to the drainfield. I really shouldn't do that as it mows better with the high-lift blades, but I'm lazy and forgetful
