So it turns out that my moms car (2002 Subaru Outback LL Bean, H6 3.0) uses a spin-on transmission filter. It uses the same M20x1.5 threads that the engine oil filter uses, and is similar in size, but costs many times more. Is there something special about a transmission filter that makes them work differently than an engine oil filter? Do the transmission filters have different micron ratings? Is the flow reversed? Do they not have a bypass valve in them, or perhaps a bypass valve with a different relief pressure? Why couldn't I just use an engine oil filter on it?
I'm ordering some Purolator PureONE PL14459 oil filters for her car, and if it's safe to do so, would prefer to use one of those instead of the expensive spin-on transmission filter.
The Purolator site also shows two different in-line magnetic Magnefine type filters available for this car. http://www.pureoil.com/smartlink/?partnum=P1319 and http://www.pureoil.com/smartlink/?partnum=P1320
