Well, you had fun, right? That’s what we do, we try to fix things with cleaners and our own maintenance regime...it’s fun, it’s better than nothing, and if it works we did it. It was us, our procedures and ideas. Problem is it rarely works. And that’s ok, this is an oil site, this is fun. It probably won’t work for many of us (freeing up rings in their groves, cleaning out the spacer in the oil control ring, cleaning varnish off the high point of a valve train).
But none of it is your fault...that engine had a lot of miles on it BEFORE you got your hands on it. And I bet you can easily put another 100,000 miles on it. And who knows? Maybe in that time some of that varnish will come off with shorter intervals using a higher quality oil/filter.
If you weren’t burning through a quart every 1,000 miles I’d suggest running HPL oil for your intervals, and then pull that valve cover off in another 20,000 miles to take a look. But you’d be spending some money doing that.
