Originally Posted By: zzyzzx
Even if you can use plugs for a long time, it's still good to remove them and check the gap.
Easy on some cars and a huge PITA on others. The real irony is that one of the reasons for long-life plugs is because it's a pain to access. And if they're not periodically checked and reinstalled, they get harder to remove.
I remember the original ND platinum plugs on my '95 Integra GS-R. While I did replace them, I regapped then against the instructions of the manufacturer because I couldn't find anything (outside dealer parts) with a 1.3 mm gap. They used to have an ad saying that Denso platinums could conceivably last the life of an engine. Even after 70k miles (more than the recommended 60k replacement interval) the gap was perfect and the platinum material intact. I actually put back the factory plugs and checked them periodically for wear. My wife's Civic actually came with NGK Laser Platinums from the factory. I just felt like doing something and replaced them. The plugs were still fine after about 65k miles and 12 years. I guess it's a bit odd that a car this easy to change plugs comes with platinum from the factory, but a lot of manufacturers use long maintenance intervals as a selling point.
Long-life plugs don't work like standard plugs. All plugs obviously get corroded from being exposed to the combustion chamber. Standard plugs supposedly fire better when they're newer with sharper edges. That's why NGK and Denso have standard plugs with extra edges like V-Power and U-Groove. They're not really gimmicky like Splitfire. The platinum and iridium plugs use a smaller platinum or iridium tip that's supposed to get hot enough to self clean. NGK and Denso are know for bigger, more durable tips.
I guess only Bosch goes to the extreme of a thin platinum wire that's buried flush with the insulator. I used to take my car to a shop (Japanese car specialist) that only stocked Denso plugs and used them in everything, including makes that didn't spec them. They could order NGKs if the customer insisted. I remember talking to the owner about when they used to use Bosch plugs. I guess their standard plugs were OK, but they kept on getting the platinum plugs back with no center electrode left.
