If the old sensor didn't corode the electric end of sensor they are probably ok as a visual check has been good enough on all the ones I have worked on then do a temp test with the fans because if it passes that then you are good to go on readings. If you want to replace the pigtail to be safe Wells/Airtex still sell the pigtail and Rockauto and Carquest still have them. The pigtail comes with heat shrink butt connectors like the OE authorized repair. PS the ECT and the intake air temp sensor and pigtail are the same parts on Saturn SL cars.
