This relates to my post about the HLP 68 hydraulic fluid I've been looking for in the United States for my Trabant's gearbox.
OK, So as of right now I'm trying to determine is Mobil's SHC 626 ISO VG 68 is the same thing as HLP 68. Seems to me the American designation of this fluid goes by ISO (irronic) and in Europe it goes by HLP.
The owner's manual says I can substitute SAE 30 engine oil or SAE 80 gear oil in it's place. But these oils seem to thick.
I poured some of this Mobil SHC 626, ISO VG 68 oil into a container and it is very thin! Actually exactly what I am looking for if it's the same thing as HLP 68 because what I am using right now (10W30 motor oil) seems too thick which won't allow the freewheel device to engage properly.
This makes no sense, wouldn't SAE 30 weight engine oil be much thinner than "68" or do these numbers mean nothing in relationship of one another?
Also HLP 68 is supposed to be a hydraulic fluid? What exactly is the difference between a hydraulic fluid and a gear oil for that matter?
I guess what I am trying to ask is, does the "30" in SAE 30 mean anything compared to viscoity grade? Why would a fluid with a VG of 68 be thinner than SAE 30 motor oil?
Also why does the oil chart below say I could use either SAE 30 engine oil or SAE 80 gear oil? Wouldn't SAE 80 be thicker than SAE 30?
I'm assuming when you start comparing engine oil to gear oil to hydraulic fluid, the numbers don't mean anything?
http://s222.photobucket.com/user/turbofi...643254396775637
