I dont know how accurate this info is, This is straight from walmart.com. All I would like to know is who is SPECIALTY OIL CO.?
Code:
Product Name Manufacturer Name
Super Tech Performance Engineered Motor Oil-All Grades Specialty Oil Company
SUPER TECH R&O ANTI-WEAR HYDRAULIC OIL ISO 46 WARREN DISTRIBUTION
SUPER TECH UNIVERSAL HYDRAULIC TRANSMISSION FLUID WARREN DISTRIBUTION
SUPER TECH MINERAL GEAR OIL SAE 90 WARREN DISTRIBUTION
SUPER TECH SAE 15W40 WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 20W50 OIL WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 GENUINE 30W MOTOR OIL WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 30W MOTOR OIL WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 DEXRON III/MERCON AUTOMATIC TRANSMISSION FLUID WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 TYPE F AUTOMATIC TRANSMISSION FLUID WARREN DISTRIBUTION
SUPER TECH SAE 30 UNIVERSAL MOTOR OIL WARREN DISTRIBUTION
SUPER TECH 5W30 FULL SYNTHETIC OIL WARREN DISTRIBUTION
SUPER TECH FULL SYNTHETIC SAE 10W30 WARREN DISTRIBUTION
SUPER TECH SYNTHETIC BLEND SAE 5W30 MOTOR OIL WARREN DISTRIBUTION
SUPER TECH SYNTHETIC BLEND SAE 10W30 MOTOR OIL WARREN DISTRIBUTION
SUPER TECH ENGINE TREATMENT SPECIALTY OIL CO
SUPER TECH STARTING FLUID VALVOLINE
SUPER TECH TILT AND TRIM FLUID WARREN DISTRIBUTION
SUPER TECH MULTI-VEHICLE AUTOMATIC TRANSMISSION FLUID WARREN DISTRIBUTION
SUPER TECH SYNTHETIC BLEND 10W40 MOTOR OIL WARREN DISTRIBUTION
SUPER TECH UNIVERSAL 2-CYCLE OIL WARREN DISTRIBUTION
SUPER TECH RV AND MARINE ANTI-FREEZE FOX PACKAGING CO
SUPER TECH MULTI PURPOSE LITHIUM GREASE WARREN DISTRIBUTION
SUPER TECH MULTI DUTY COMPLEX GREASE WARREN DISTRIBUTION
SUPER TECH MOLY LITHIUM GREASE WARREN DISTRIBUTION
SUPER TECH MARINE GREASE WARREN DISTRIBUTION
SUPER TECH 0 DEGREE WINDSHIELD WASHER FLUID SOUTHWIN LTD
SUPER TECH AUTOMATIC TRANSMISSION FLUID WARREN DISTRIBUTION
SUPER TECH 75W140 SYNTHETIC GEAR OIL WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 GL-5 SAE 80W90 GEAR OIL WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 GL-5 85W140 GEAR OIL WARREN DISTRIBUTION
SUPER TECH FULL SYNTHETIC - ALL GRADES SPECIALTY OIL / PENNZOIL QUAKER STATE
SUPER TECH OUTBOARD 2 CYCLE ENGINE OIL TC-W3 SPECIALTY OIL / PENNZOIL QUAKER STATE
SUPER TECH MINERAL GEAR OIL SAE 90 SPECIALTY OIL / PENNZOIL QUAKER STATE
SUPER TECH AND TECH 2000 10W30 MOTOR OIL WARREN DISTRIBUTION
SUPER TECH SYNTHETIC BLEND MOTOR OIL - ALL GRADES SPECIALTY OIL / PENNZOIL QUAKER STATE
SUPER TECH +22 F WINDSHIELD WASHER FLUID FOX PACKAGING
SUPER TECH 10W40 EXXON MOBIL
SUPER TECH R AND O ANTI WEAR HYDRAULIC OIL AW 46 SPECIALTY OIL / PENNZOIL QUAKER STATE
SUPER TECH SAE 30 UNIVERSAL MOTOR OIL PENNZOIL QUAKER STATE
PMDC: SUPER TECH SAE 30 UNIVERSAL MOTOR OIL PENNZOIL QUAKER STATE
SUPER TECH AND TECH 2000 WINDSHIELD WASHER FLUID -25F FOX PACKAGING
SUPER TECH WINDSHIELD WASHER FLUID -20F FOX PACKAGING
SUPER TECH MARINE OUTBOARD 2 CYCLE ENGINE OIL TC-W3 SPECIALTY OIL / PENNZOIL
SUPER TECH MARINE HIGH VISCOSITY 80W90 LOWER UNIT GEAR LUBRICANT SPECIALTY OIL / PENNZOIL QUAKER STATE
SUPER TECH CORROSION CONTROL AND TRAILER WHEEL BEARING GREASE SPECIALTY OIL / PENNZOIL QUAKER STATE
SUPER TECH CONCENTRATED FUEL INJECTOR CLEANER PENNZOIL QUAKER STATE
SUPER TECH GAS TREATMENT PENNZOIL QUAKER STATE
SUPER TECH POWER STEERING FLUID PENNZOIL QUAKER STATE
SUPER TECH HIGH PERFORMANCE BRAKE FLUID DOT 3 PENNZOIL QUAKER STATE
SUPER TECH UNIVERSAL 2 CYCLE ENGINE OIL PENNZOIL QUAKER STATE
SUPER TECH 80W90 AND 85W140 GEAR LUBRICANT SPECIALTY OIL
SUPER TECH MARINE POWER TRIM AND TILT FLUID PENNZOIL QUAKER STATE
SUPER TECH SAE 30 UNIVERSAL HEAVY DUTY DIESEL ENGINE OIL PENNZOIL QUAKER STATE
SUPER TECH PERFORMANCE ENGINEERED HD SAE MOTOR OIL - ALL GRADES SPECIALTY OIL CO
SUPER TECH HEAVY DUTY TRACTOR HYDRAULIC AND TRANSMISSION OIL SPECIALTY OIL / PENNZOIL QUAKER STATE
SUPER TECH R&O ANTI WEAR HYDRAULIC OIL AW 46 SPECIALTY OIL
SUPER TECH FUEL INJECTOR AND CARBURETOR CLEANER SPECIALTY OIL
SUPER TECH TYPE F AUTOMATIC TRANSMISSION FLUID SPECIALTY OIL / PENNZOIL QUAKER STATE
SUPER TECH DEXRON III / MERCON AUTOMATIC TRANSMISSION FLUID SPECIALTY OIL / PENNZOIL QUAKER STATE
SUPER TECH BAR & CHAIN OIL GRADE 30 SPECIALTY OIL / PENNZOIL QUAKER STATE
SUPER TECH SAE 15W40 UNIVERSAL MOTOR OIL SPECIALTY OIL / PENNZOIL QUAKER STATE
SUPER TECH PERFORMANCE ENGINEERED MOTOR OIL - ALL GRADES SPECIALTY OIL / PENNZOIL QUAKER STATE
SUPER TECH ANTIFREEZE / COOLANT HONEYWELL
SUPER TECH WINDSHIELD WASHER PREMIUM DEICER -30 FOX PACKAGING
SUPER TECH OIL TREATMENT NATIONAL INTERCHEM LLC
SUPER TECH 10W30 EXXON MOBIL
SUPER TECH HD 30 EXXON MOBIL
SUPER TECH AND TECH 2000 5W30 MOTOR OIL WARREN DISTRIBUTION
SUPER TECH BAR AND CHAIN OIL SAE 30 WARREN DISTRIBUTION
SUPER TECH ENGINE DEGREASER HYDROSOL INC
SUPER TECH CARB CLEANER HYDROSOL INC
SUPER TECH WHITE GREASE HYDROSOL
SUPER TECH MULTI LUBE HYDROSOL
SUPER TECH 5W30 EXXON MOBIL
SUPER TECH 50/50 ANTIFREEZE AND COOLANT OLD WORLD INDUSTRIES
SUPER TECH 20W50 EXXON MOBIL
SUPER TECH WINDSHIELD WASHER FLUID FOX PACKAGING COMPANY
Super Tech Starting Fluid Technical Chemical
SUPER TECH GAS TREATMENT FIRST BRANDS
SUPER TECH FUEL INJECTOR AND CARBURETOR CLEANER FIRST BRANDS
SUPER TECH 5W30 MOTOR OIL WARREN DISTRIBUTION
SUPER TECH DEXRON III MERCON AUTOMATIC TRANSMISSION FLUID WARREN DISTRIBUTION, INC.
SUPER TECH SAE 75W90 SYNTHETIC BLEND GEAR LUBRICANT WARREN DISTRIBUITION
Super Tech Wash and Wax SOUTH WIN
SUPER TECH MARINE 80W90 GEAR OIL WARREN DISTRIBUTION
SUPER TECH +32 WINDSHIELD WASH FOX PACKAGING COMPANY
SUPER TECH SUMMER WINDSHIELD WASH FOX PACKAGING COMPANY
-20F SUPER TECH WINDSHIELD WASHER FLUID FOX PACKAGING COMPANY
-25F SUPER TECH WINDSHIELD WASHER FLUID FOX PACKAGING COMPANY
WALMART SUPER TECH 2000 5W30 MOTOR OIL WM0453PL WARREN
SUPER TECH TCW3 2 CYCLE OIL WM06104P WARREN
WALMART SUPER TECH 2000 20W50 MOTOR OIL WARREN
SUPER TECH 15W40 WARREN
WALMART SUPER TECH 5W30 FULL SYNTHETIC OIL WARREN
SUPER TECH 15W40 WM5546PL WARREN
WALMART SUPER TECH 10W30 FULL SYNTHETIC OIL WM13FHPL WARREN
SUPER TECH AW HYD ISO 46 WM52462G WARREN
SUPER TECH POWER TILT & TRIM FLUID WM660010 CHEMTOOL INC
SUPER TECH UNIVERSAL SAE 30 WM05302G WARREN
SUPER TECH MULTI PURPOSE LITHIUM GREASE WM610003 WM610014 WARREN
SUPER TECH MULTI DUTY COMPLEX GREASE WM620014 WM620016 WARREN
SUPER TECH GL5 85W140 GEAR OIL WM55143P WARREN
SUPER TECH GL5 80W90 GEAR OIL WM18903P WARREN
SUPER TECH AW HYD ISO 46 5GL WM52465P WARREN
SUPER TECH BAR & CHAIN WM38BCPL WARREN
SUPER TECH HIGH MILEAGE SAE 10W30 WARREN DISTRIBUTION
SUPER TECH HIGH MILEAGE SAE 10W40 WARREN DISTRIBUTION
SUPER TECH FULL SYNTHETIC MOTOR OIL - ALL GRADES SPECIALTY OIL
SUPER TECH UNIVERSAL HYDRAULIC TRANSMISSION FLUID WM25UN2G WARREN DISTRIBUTION
SUPER TECH AIR COMPRESSOR OIL WARREN DISTRIBUTION
SUPER TECH AIR TOOL OIL WM06AT08 WARREN DISTRIBUTION
SUPER TECH 2000 RV AND MARINE ANTIFREEZE FOX PACKAGING CO
Super Tech White Grease (AEROSOL) Technical Chemical Co.
Super Tech Carburetor Cleaner Technical Chemical Co.
Super Tech SAE 10w30 Motor Oil Warren Distribution Inc
SuperTech Premium Water Remover 4PK South/Win LTD.
SuperTech Gas Line AntiFreeze 4PK South/Win LTD.
SuperTech Gas Line AntiFreeze South/Win LTD
Super Tech Marine HV 80W-90 Lower Unit Gear Oil Specialty Oil Company
Super Tech Marine Power Tilt and Trim Fluid Specialty Oil Company
Super Tech Universal Heavy Duty Diesel Engine Oil (All Grades) Specialty Oil Company
Code:
