One of the things I read on BITOG is that some folks prefer a 10w30 to a 5w30 oil because it has a higher HT/HS and provides greater protection. However, I've noticed that many 5w30 oils have a higher viscosity and, from what I've read here, that would equate to a greater HT/HS. Since I'm a Mobil 1 user, I'm most familiar with their specs, although I've seen similar numbers with other brands. For example, here are the numbers for Mobil 1 Extended Performance:
So what, if anything, makes the 10w30 a more desirable or stronger oil than the 5w30? Might it be that the 10W has less or different viscosity improvers? Would this 5W have a greater HT/HS than the 10W?
