While shopping for a new Z turn commercial mower, I learned that some companies have changed their oil recommendations. I looked at a Toro which used 10-30, Big Dog Kaw 10-40, and a Ferris with B&S commercial 30w. The Toro was their own "commercial" Chinese made engine with a nylon cam gear. That came off my list. The Ferris dealer told me that Kaw. had gone to 10-40. They had some internal engine part failures (maybe plastic). The Ferris which I bought has the Briggs Commercial turf engine and recommends 30w. It says in the manual that if you use 10-30 in hot weather, it will consume more oil. I traded a 10 yr old Kawasaki that always had 10-30 syn and never used a drop.
IMO these manufacturers are in the process of moving to heavier oils. This is probably due to the engines running so lean and hot due to EPA mandates. Their are no adjustments in the carbs and they even have solonoids in the carbs to shut off fuel when the switch is turned off so no backfiring. EPA doesn't care how long engines last but we owners do.
I think you are going to see heavier oils recommended in the future to at least get us out of warranty. Once my engine is broken in on the Briggs 30 w, I'm leaning toward a 10-40 or 15-40 HDEO.
What say ye BITOGers?
