Originally Posted By: fdcg27
If Toyota thinks that its V-6 is fine with anything from a 0W-20 to a 20W-50, then it is. Nothing changes between NA and Australia other than the grade recommendations.
The engine will outlast the vehicle in which it's installed either way.
See, that's contrary to my thinking. I took over Pops pick-up when it was on its second engine and we drove it through its third engine, out to over 0.5M miles.
Most of my cars from boyhood on have lived long enough for two engines at least. It's how I learned to wrench... A lot of the relatives are the same.
We don't have snow or salt... So bodies tend to last a l-o-n-g time. Interiors need a spruce-up around 200,000 miles and that's often when it'll get a motor as the power is down and fuel consumption is up. It has not quit running, or started missing. Oil is not being gulped, but in general, its engine getting a bit long in the tooth.
It's also time to up the game a bit. Bump the CR, cam it a bit more. If we've been looking at ten years worth of SMOG tests, we have a pretty good idea what we can get away with and still pass
That's why I know what the internals look like under varying maintenance regimens... I do some relatives motors now and then and I see what extending OCI's looks like on Jiffy Lube bulk oil. I also get to see what my motors look like if I have to back in for some reason like leaking manifold gaskets (coolant issues), or a carb and manifold change. EFI is more forgiving, but still...
We only recently sold some of the farm trucks due to the brothers passing (Uncles). 1938 Dodge 1 1/2 ton flatbed prolly had 6 engines in it's life. The 1956 Ford F600 maybe four (Y-blocks). These trucks worked hard, pulling hills with trailers with farm equipment on them. The 1938 Chevy "Saw Car" (runs a buzz saw in the woods) had at least three engines and it hardly ever saw the road.
The diesel stuff is different. Gasoline engines tend to wear faster. More highly stressed components and nastier combustion by-products. The light duty trucks and passenger cars tend to last until they can't be given to a younger relative - no one wants them. Too old, old fashioned, not cool, etc. But unless wrecked, the motors go sooner than the rest ...
Consequently, we care about lubrication. Delo400 15W-40 for most of the fleet. Chevron Supreme 10W-30 for the rest. Occasionally, someone will get a car or light truck that will start out on 5W-30... But as soon as it's done with warranty, it gets what we have from the distributor.
Now that I live away from the farm, I get to play with more different kinds of lubes. But I still have jugs of what we used farming for those motors that do well on that.
I guess, if I ever get a 201X vintage something, I'll look at maybe some lighter oils. But I have some BBC's to build before that will happen
