solvent for cleaning the turbo pressure sensor
Charlotte, NC
My diesel Jeep has a turbocharger boost pressure sensor down stream of the turbo that needs cleaning periodically for the engine computer to give a good signal. Keeping it clean is worth 3 mpg.
What would be a good solvent for cleaning it? Brake cleaner, carb cleaner, xylene?
is it electrical?
residual-free contact cleaner helps but ultimately, you'll have to find out what causes the conductivity to go bad (heat? moisture? vibration? corrosion?)
