Solid-state battery from US cell maker hits new milestone
NJ
"Based in Massachusetts, Factorial Energy has been working on its lithium-metal quasi-solid-state technology for over a decade, attracting backing and collaboration from major automakers like Stellantis, Mercedes-Benz and Hyundai. It's aiming for a long-range, energy-dense battery that costs the equivalent of lithium-ion units and rolls off the same production lines. This month, it sent out its first round of B-samples to Mercedes-Benz for further testing and development."
https://newatlas.com/automotive/factorial-solid-state-battery-b-sample/
Gasoline fires are burning out of control at the moment due to bad judgement. Besides the hazards and destruction, gasoline is a dirty fuel.
Do you actually work with batteries, and more specifically on battery safety?
I doubt it.
No, its vastly different.
One of the banes of existence in even Li-ion (emphasis ion, so no metal present) is the dissolution and plating of metallic dendrites that pierce the separator and start a hard, low impedance short.
In a li-ion battery, this is only a tiny bit of metal, followed by an electrolyte fire and decomposition of cathode.
In a Li-metal battery, this would result in a fire of some components, triggering a class D metal fire which is a major challenge to get out.
Since current firefighting doctrine recommends deluge or water mist to remove latent heat, now we can’t even apply that because water on a metal fire is horrendously dangerous. And now firefighters need to be battery experts to know which type might be in a vehicle.
These aren’t coin cells. This isn’t imagination about being green. It’s real, major loss and safety considerations.
Vastly different than your straw man.
My 20lb CO2 fire extinguisher will easily put out a gasoline fire. A small one with one squirt of CO2. All 20lb of CO2 won't even touch a battery fire.
You might consider 'could' . I think battery fires are not inevitable.
Technology will move forward as it did with gasoline.
I've been a critic of battery claims forever. The linked article is no exception. Quote: "ranges over 600 miles (966 km) per charge from a 90-kWh battery" NONSENSE.
90kWh is a specific amount of energy that can provide a real world 90 HP for one hour, or 45HP for 2 and so on.
Let's take this to it's conclusion. 600 miles is 8 hours of driving at 11HP continuous. Haha, no. 150 Watt hours per mile? Utter nonsense.
