How do I solder a piece of thin aluminum wire to a terminal that comes from the slip ring to a generator rotor?
I have a Champion generator, with less than 1 hour run time and a broken wire that feeds the terminal to one of the slip rings on the rotor. Rather than use copper, they use aluminum for the windings (cheap!). Still under warranty but I lost the receipt
Moving on.
I have it all apart on my kitchen floor. I want to repair it, or at least try to, and as last resort before using it as a $300 boat anchor.
The strand really is very thin. Will it hold up to the heat of a soldering iron? Also, the wire has a very thin layer of insulation that I'm afraid will break the wire if I try to strip it. Will the heat of the soldering melt off the insulation adequately to make a good contact?
Moving on.
