What size sockets will I need to get the skid plate and anything else out of the way to do an oil change on my 2020 Ford Edge SEL? Any extensions or joints ?
I'd recommend you head to Youtube. Not only will you know the tools you need you'll also know the locations of everything and any potential pain points.
Find a youtube video, some give that info, some dont.
Chances are your standard metric socket set 10mm-19mm with a few extensions is what you will need, plus a filter wrench.
To OP: If this is your first oil change?
DO NOT use a disposable baking tin as an oil catch-as shown in the video in post #3.
They're very flimsy and, frankly, a foolish thing to use. Get a catch pan with a spout.
The spout easily fits into whatever transfer jug.
If it's like my 2013 Edge, it'll be a 15mm socket for the drain plug. If using an oil filter wrench that attaches to a ratchet, a short extension is a good idea. My Edge doesn't have any covers.
