swivel adapter/socket for changing spark plugs?
Originally Posted by user52165
You are more likely to exert side force with a wobble or swivel than without.
Funny.
So your one of "those" guys.
Ask a ton of questions and try to make yourself look smart.
I use my spark plug tool to keep from exerting side force on the spark plug.
Before I had a tool, I used a universal joint with tape wrapped around it hold it a little tighter.
The tool I have does not swivel enough to help get around things.
I'll use my tools the way I see fit and you can do the same.
Originally Posted by NissanMaxima
Hi all:
Quick question for the board. I've changed spark plugs in the past on Toyotas and am getting ready to do the job on my Maxima. Is there any advantage of using one of these swivel spark plug sockets I've seen or as long as I've got a straight shot for access, just a regular spark plug socket and extension should be fine right? I'll be using a torque wrench and I'm also thinking it might be better to avoid any swivel heads if possible. Thanks
What does Toyota say?
Here's what BMW has to say,
"Unscrew spark plugs with special tool 12 1 220 and extension with minimum 8° bend. Flexible ratchet extensions must always be used. If rigid mounting tools are used, there is a risk of insulator breakages."
Now to get really technical, https://www.terex.com/docs/librariesprovider7/tech-tips/techtip_53.pdf?sfvrsn=1371ae74_4
