Picked up a friend's snowblower this summer, saw that it had an oil leak but figured it couldn't be too bad... Realized it was leaking pretty badly so I dug into it today. Realized that it was probably coming off the front seal, and voila! once I got the flywheel off the seal was sitting all the way out. Like it hadn't been installed. I tapped it back in place--seemed a bit loose but still had to be pushed into place--and buttoned it up. I think it kicked it out again though. So I pulled the dipstick while it was running and it sure feels like a lot of blowby. This isn't that old, oil doesn't look bad (but it doesn't say in for very long!), starts decently on the pull start. I have a compression tester but will it work on this? I'm not sure if I can pull it fast enough to get a good reading--I know on the older B&S motors they had a decompression ramp on a lobe that prevented this testing.
It's an MTD with 179cc engine, a 600 series snowblower by the manual. Seemed to move snow ok, I'd be tempted to ignore but if it's leaking then it's wetting down the friction drive.
