There's still time to get that snow shovel waxed up...PSA this is why we prepare them before the season starts.
We use the wire from twist-ties for small engines.A trick that I learned last year from a neighbor who repairs mowers in his spare time. He told me alot but not all carb jets have a tiny starting jet. He uses a welder tip cleaning tool. I useda tiny paperclip as they can get build up. Gaskets get hard and go bad. Then there's the float bowl which can gunk up and not move freely.
Many times I have encountered a corroded and pitted hinge pin for the float on those carbs resulting in a stuck float. It results in either in flooding gas or no gas at all depending where the float sticks. Before I dig in, I would try tapping the bowl with something.@Donald sorry no one is answering your question!
This was from a Honda EU2000i generator my nephew left gas in for a year or two. We cleaned the jets and then put everything in an ultrasonic cleaner.
The fuel bowl was pretty clean. Nothing like @Ranger83's fuel bowl. Just a tiny about of crud at the bottom that I wiped out.Yeah you might not need to completely remove the carb if you can just get the float bowl off the bottom. Fiddle with the float and its hinge pin, blast upwards through the main jet with carb or brake cleaner. Reassemble, use a little starting fluid, she'll come to life. Might surge for a while since you didn't clean the idle passage but it'll move snow. Your carb bowl will look like @Ranger83 picture but you can wipe that out.
Everyone is postulating about what might be wrong with the carb.Many times I have encountered a corroded and pitted hinge pin for the float on those carbs resulting in a stuck float. It results in either in flooding gas or no gas at all depending where the float sticks. Before I dig in, I would try tapping the bowl with something.
What he asked was how to get access.
I would like the carb and all it's glory to be hanging it all out. I don't need a shroud to make it pretty. Shroud around muffler to prevent burned fingers I am OK with.Everyone is postulating about what might be wrong with the carb.
Safety shroud yes, make-pretty shroud no.
Took of the cover for the belts to get access to a bolt and mouse nest under the cover.
You must be a lot stronger that this 71 year old. Neither #3 or #4 pulled straight off. Pry off or bang off with a screwdriver.You need to:
1) disconnect the primer hose from the bulb
2) disconnect the leads from the back of the key
3) remove the choke knob (pull straight off)
4) remove the throttle lever cap (pull straight off)
This will allow the shroud to come off pulling towards the rear of the machine. To get the carb off the mounting bolts you may have to loosen a handle bolt or two to flex the handle rearward to allow clearance.
It's no wonder people are getting away from gasoline powered equipment; I would too if I had to deal with this stupidity.Been having nothing but problems with my new $1400 2 stage HD Toro with cheap Chinese engine and carb. Never ever had an issue with my Tecumseh S-K over 27 years. The new Toro have a tiny "inaccessible" fuel filter in the gas tank outlet (dealer said no filter - morons!) Got a new carb from TORO and it was defective!
This is why I use an electric snowblower.PSA this is why we prepare them before the season starts.
