D
Deleted member 89374
I would take the Prius + Chains. Have fun & enjoy your trip
Interesting responses, thank you. I have zero experience with driving in the snow, so that is definitely a factor to consider. I do not plan to drive up to Tahoe when it is actively snowing - only after a storm once the roads are plowed. So, the consideration for snow exposure is more of a just-in-case.
Which brand of tire chains should I consider buying?
FCA specs a "S-type" chain for the truck.
Honda says: "Link-type: SCC Quick Grip QG1134 Cable-types: SCC Radial Chain CH2311T or SCC SC Cable SC1030"
Toyota says:
Pickup with 150lbs of sand in the bed over the rear wheelsI would like to take a trip up to Lake Tahoe. Which of my vehicles should I take?
2020 Ram 1500 Crew Cab- 2WD, mechanical LSD, OE Goodyear Tires with 10/32" remaining.
2011 Prius - has brand-new Pirelli P7 All Season Plus II Tires.
2007 Honda Accord - has Continental PureContact LS Tires with 9/32" remaining.
I do not own chains for any of these vehicles so I will need to purchase. However, would any of these be a better candidate for the snow (than the others)?
Agreed.Perfect timing.....We have 14" on the ground so far and it's still coming strong. This storm is a good one! Light, fluffy, powder! We often get heavy crud and some ice mixed in.
2WD PU is a no go.
Prius is horrendous in snow, especially if you have hilly terrain to deal with.
Accord is your best bet. Tires matter.
I have never experienced the rear end violently stepping out as you described on my Ram... or my RWD 300 because RWD isn’t as dangerous as you’re making it out to be. Between traction control, stability control, and not flooring it on snow/ice, anyone will be fine. Just drove through 11” of snow yesterday in 2WD on the OEM Goodyear’s and it never kicked out once, even on the ice covered curves.A 2wd truck with LSD is a fantastic way to die. If one wheel spins, the other one stays planted and helps point the truck. But if they both spin because the LSD makes them, you go from perfectly fine to 90-degrees sideways, possibly into the oncoming lane. And all-season tires do NOT have the lateral grip in snow. Once they break free they go from static to sliding friction and are just hopeless. Actual winter tires will fight when going sideways and respond to driver inputs like you'd expect.
If I slip at all, it takes all power away from the wheels for a second or two, leaving it stalled in an intersection when I'm trying to get going. And if by some miracle I am moving, the ABS removes braking power from all wheels for a similar time if I hit one little slick spot.
The FWD ones, since you have the engine and transmission putting weight on the front axle. The 2WD truck, with a empty bed, doesn't have much weight on the rear axle to help with getting power to the ground... you'll need to weigh down the bed with some sand bags.I would like to take a trip up to Lake Tahoe. Which of my vehicles should I take?
