All were pushed into the corner with whatever treated gas that was in them, none had more than 1/4 tank... Each was filled with same gas I bought last fall...
The '87 on right lit off first pull on the rope... Of course I use the 90* tilt method(spark plug down for two sec) before cranking to be sure the primer well in the pulsa-jet carb is full...
The '83 Hondaized refused to light with three pulls on full choke, so off came air cleaner and was treated to a blast of starter fluid... With that it fired first time and was slinging grass 15-20 sec later... Three days later started first pull, always seems finicky on first start of season, with regular use starts first or second pull...
Grandpa Snapper with the 1980 Montgomery Ward Briggs started first pull, procedure same as the '87...
The 2004-ish Tecumseh lawn vac never starts without help(primer bulb is useless), so it gets a shot of ether before any cranking is done... Still took four or five pulls before I got it's attention, ran fine once it started... I don't feel it's worthy of a pict...
