I have a smell of gas in my Pontiac 400 which I check the dip stick. I was told by some drag racers and dirt track racers in my area that in a modified engine for racing or hard use with big cam/rich carb you will smell some gas in oil. Does anybody else ever have this problem with carburated engines?
I am running the carb a little on the rich side. However not enough for the exhaust fumes to burn your eyes. I do have .005 extra clearance on my cylinders for the forged pistons. fuel pump in in good shape. I was using 20w50 Valvoline and am now using Royal Purple 15w40.
Also if this engine is going to run on the rich side, should I go back to the 20w50 to compensate for fuel dilution. What do you think?
