On my zero turn ( 21hp kawasaki fr651v) i run a fram ultra 3614 filter. Is there any downside to running a 3600? ( same filter baseplate, filter is just longer)
the 3614 fits and seems to work fine, bypass is 12.Isn’t the 4967 the correct filter?
The OE Kawasaki filter crosses over to the 4967. That’s the reason I asked.the 3614 fits and seems to work fine, bypass is 12.
Basically i compared the original filter to ones in my used bucket when i bought the mower. the 3614 that i used on saturns seemed to be almost the same, so i used that.
Should I use the 4967 over the 3614?The OE Kawasaki filter crosses over to the 4967. That’s the reason I asked.
I use the TG 4967 on my Kawasaki Mule and my Toro ZTR. It’s just easier for me. Plus, my Toro has the 24.5 hp Loncin engine (Chinese Kawasaki clone). It will only except the OE Toro/Exmark filter, the 4967 or STP S-4967. As long as you are not having leaks from the mounting flange, you are probably okay with what you’re using.Should I use the 4967 over the 3614?
That finned piece of metal is more for looks than function.
Thanks, i'll leave it off.Someone claimed to have run tests with a finned thing like yours.
He claimed to have slathered the filter with electronics heat conductor paste (pookie?) first for some tests.
He concluded it made no measurable effect.
Now, if he'd painted it flat black?
