So I have a bit of Lift in my cherokee. The driveline angles on the rear driveshaft aren't that bad from what I've been told.
If I just drive to and from work, I can get unlimited miles out of the front u joint in my rear driveshaft.
If I have an extended highway run or drive it 40 or 50 miles straight, the U joint starts vibrating.
If I grease the U joint ON the vehicle, it doesn't help. When I pull it off, I can see that the U Joint is nearly set up. However, if I take it off, grease it and work it through it's FULL range of motion ... it operates like new.
When I grease them, I wipe off all of the extra grease. But what I notice when pulling off the shaft is that the U joint is coated in oil.
Is it possible that I'm making the oil actually come out of the joint leaving just the carrier in there?
