- Joined
- Sep 28, 2002
- Messages
- 39,798
Originally Posted By: BrianWC
ATF has changed over time, from what I understand. However, the only good explanation I've heard for any cleaning capability is it's light 20 weight which might remove some not so stubborn loose crud in the engine.
The para-myth was supported by GM endorsing the use of ATF to quiet lifters in some SBC engines in the late 60's-early 70's. It was assumed that the lifter tick was due to fouled lifters. The ATF was used as a thinning agent for the oil. Viola~ ATF is then regarded as a cleaner.
