Slow Modem download
Quattro Pete: I opened the Advanced field then modem/router field then Connection. What should I be looking for that might be causing my issue?
"][QUOTE="OVERKILL, post: 5482629, member: 21028
OK, but this modem was originally 25Mbit when you first connected it, correct? And then it dropped down to 5Mbit? And the Comcast modem was also giving you 25Mbit, correct?
[/QUOTE]
Connection
eRouter
eRouter Provisioning Mode
Startup Sequence
Startup StepStatusComment
Acquire Downstream Channel555000000 HzLocked
Upstream ConnectionOKOperational
Boot StateOKOperational
Configuration FileOK
SecurityEnabledBPI+
Connection Status
System Up Time2 days 23h:32m:22s
Network AccessAllowed
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFreq. (MHz)Pwr (dBmV)SNR (dB)CorrectedUncorrected
1LockedQAM25613555.0 2.139.710
2LockedQAM2569531.0 2.939.920
3LockedQAM25610537.0 2.539.920
4LockedQAM25611543.0 2.639.910
5LockedQAM25612549.0 2.339.720
6LockedQAM25614561.0 2.139.710
7LockedQAM25615567.0 2.139.910
8LockedQAM25616573.0 2.039.800
9LockedQAM25617579.0 1.839.8110
10LockedQAM25618585.0 1.739.800
11LockedQAM25619591.0 1.739.82631
12LockedQAM25620597.0 1.839.800
13LockedQAM25621603.0 1.839.700
14LockedQAM25622609.0 1.939.700
15LockedQAM25623615.0 1.939.600
16LockedQAM25624621.0 1.939.71895
17LockedQAM25625627.0 2.641.12161
18LockedQAM25626633.0 2.541.11864
19LockedQAM25627639.0 2.341.01864
20LockedQAM25628645.0 2.141.12358
21LockedQAM25629651.0 2.041.11964
22LockedQAM25630657.0 1.840.81666
23LockedQAM25631663.0 2.141.01865
24LockedQAM25632669.0 2.041.11864
19LockedQAM25627639.0 2.340.91864
20LockedQAM25628645.0 2.140.92358
22LockedQAM25630657.0 1.840.71666
23LockedQAM25631663.0 2.041.11865
Total 453602
Upstream Bonded Channels
ChannelLock StatusChannel TypeChannel IDSymb. Rate (Ksym/sec)Freq. (MHz)Pwr (dBmV)
1LockedATDMA7512016.642.8
2LockedATDMA1512035.844.8
3LockedATDMA2512029.443.5
4LockedATDMA3512023.043.0
5Not LockedUnknown000 0.0
6Not LockedUnknown000 0.0
7Not LockedUnknown000 0.0
8Not LockedUnknown000 0.0
Downstream Frequency Setting
Downstream Frequency Select
Network WAN Connection
IPv4 Address73.54.56.9
Time Since LeaseD: 04 H: 00 M: 00 S: 00
Lease Expiration TimeTue Jul 28 08:14:56 2020
IPv6 Addressfe80::240:36ff:fe66:ac83/64
2001:558:6015:15:e1e8:6ea5:67fc:7280/128
MAC Address00:40:36:66:ac:83
IPv6 DNS Servers2001:558:feed::1
2001:558:feed::2
WAN Connection TypeDHCP
IPv4 DNS Servers
Obtain Automatically from MSO
Primary DNS...
Secondary DNS...
If I'm reading this correctly, channels 16-24 seem to have some uncorrected errors. This could potentially indicate a poor connection/link quality from the service provider.
What are you seeing under "Diagnostics" and "Event Log" tabs?
Log
Time Priority Description
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=00:40:36:66:ac:82;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=00:40:36:66:ac:82;CMTS-MAC=00:01:5c:85:2c:73;CM-QOS=1.0;CM-VER=3.0;
Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6
Mon Jul 13 10:46:42 2020 Notice (6) SW Download INIT - Via Config file d11_v_mt7711ims_speedtierextreme2_c02.cm
Mon Jul 13 10:46:42 2020 Warning (5) MDD message timeout;CM-MAC=00:40:36:66:ac:82;CMTS-MAC=00:01:5c:85:2c:73;CM-QOS=1.1;CM-VER=3.0;
Mon Jul 13 10:47:28 2020 Notice (6) SW download Successful - Via Config file
Mon Jul 13 12:55:17 2020 Warning (5) MDD message timeout;CM-MAC=00:40:36:66:ac:82;CMTS-MAC=00:01:5c:85:2c:73;CM-QOS=1.1;CM-VER=3.0;
Tue Jul 14 11:00:58 2020 Warning (5) MDD message timeout;CM-MAC=00:40:36:66:ac:82;CMTS-MAC=00:01:5c:85:2c:73;CM-QOS=1.1;CM-VER=3.0;
Fri Jul 17 13:16:53 2020 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=00:40:36:66:ac:82;CMTS-MAC=00:01:5c:85:2c:73;CM-QOS=1.1;CM-VER=3.0;
Mon Jul 20 13:00:08 2020 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=00:40:36:66:ac:82;CMTS-MAC=00:01:5c:85:2c:73;CM-QOS=1.1;CM-VER=3.0;
Wed Jul 22 14:12:26 2020 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=00:40:36:66:ac:82;CMTS-MAC=00:01:5c:85:2c:73;CM-QOS=1.1;CM-VER=3.0;
