Slime & dryrot
Near the beach in Delaware
The rear tire of my Husqvarna lawn tractor was flat after the winter. I filled it and saw some stuff bubbling out of a dry rot crack. I assume the Slime stays liquid until it oozes out. I did not add any Slime, maybe prior owner did. I am hoping to put off dealing with the tire until fall as other more important projects.
Originally Posted By: BigCahuna
if you have cracks in the tires large enough to have tire sealant leak out of, I'd say those tires are shot.,,
Yep, I changed mine out after the dry rot set in.
Wasnt worth messing with.
It seems to be holding after I filled the tire. I will get new tires, but want to do some other spring projects first. Its not that critical, I can mow my lawn with a self propelled walk behind if needed (at this point that its needed to get me exercise).
I found that using slime in dry rotted mower tires doesn't stop the leak, but it will slow it down a lot. To the point where you might only have to add air every few times instead of before every mowing.
