Slightly defective O2 sensor on 2005 Ford Taurus?
New Brunswick
My dad said the Check Engine light was on in his car so I hooked up my Ultragauge and got 2 codes, P0171 and P0174. I cleared those codes then set the Ultragauge to monitor short term and long term fuel trim and drove the car around for about an hour. I assume that on a well running engine, the short term and long term fuel trim numbers should be pretty close for both engine banks, but on my dad's car it looks like the short term and long term fuel trim for bank 2 is a bit higher than bank 1. I also noticed that under moderate to hard throttle, short term and long term fuel trim for engine bank 1 will go to 0, short term trim for bank 2, sensor 1 usually stays at about 2.3-2.6, and the long term for bank 2 goes to 0. I'm not sure what to make of that information. Maybe a failing primary oxygen sensor for bank 2 of the engine?
Your car is running lean on both banks, it is not a sensor problem. Look for vacuum leaks and pay close attention to the pcv tube. Also the maf could be dirty or defective. Make sure air cleaned is properly installed. Dont replace the oxygen sensors, they a working and telling the pcm that its running lean.
Also if its a pushrod engine look at the back of the upper intake for the intake manifold runner control actuator, the o ring was prone to develop vacuum leaks.
Those numbers for fuel trims look a bit too close to zero to be setting a code. Check your fuel trims with a stone cold engine, A leaky intake gasket will show up best with a cold engine at idle. Check your fuel trims under acceleration. A clogged fuel filter or malfunctioning MAF should be most visible when fuel demand is high.
