CEL on wife's Mazda CX-9
New Orleans
My wife called in a panic that her check engine light was on. Luckily, it was on and not flashing so I told her to go ahead and drive home. This morning I hooked up my simple code reader and laptop and pulled the code and information. It shows a P2A04 code. I have never really gotten into working on her Mazda (a 2013 CX-9 with v6 engine), sticking with my older Honda.
Anyway, this is the first time I have used this program and maybe I am getting too much information and have no idea where to start. I attached the data from the scanner in hopes that someone here can point me in the right direction to start.
Thanks
This report is generated on: 2019-5-2 6:19:53
Vehicle VIN: JM3TB2CA9D0407299
Pending DTCs
P2A04
O2 Sensor Circuit Range/Performance Bank 2 Sensor 2
Active DTCs
P2A04
Freezeframe: 0 DTC: P2A04
FT86 engine oil temperature
-40.00 C
-40.00 F
Fuel system 2 status
NODATA
Fuel system 1 status
Closed
Calcualted engine load value
61.96 %
Engine coolant temperature
80.00 C
176.00 F
Short term fuel trim - bank 1
3.13 %
Long term fuel trim - bank 1
4.69 %
Short term fuel trim - bank 2
1.56 %
Long term fuel trim - bank 2
3.91 %
Engine rpm
1677.25 RPM
Vehicle speed
20.00 KPH
Vehicle speed
12.43 MPH
Ignition timing advance for cylinder 1
28.50 Deg
Intake air temperature
28.00 C
82.40 F
Air flow rate from mass air flow sensor
29.60 g/s
Absolute throttle position
22.75 %
Oxygen sensor output voltage bank 1 sensor 2
0.12 v
Short term fuel trim associated with O2 sensor bank 1 sensor 2
99.22 %
Oxygen sensor output voltage bank 2 sensor 2
0.00 v
Short term fuel trim associated with O2 sensor bank 2 sensor 2
99.22 %
Time since engine start
421.00 sec
Commanded Evaporative Purge
25.10 %
Fuel Level
92.16 %
Number of warm up since DTC cleared
255.00
JK 2012~2017 auto transmission fluid temperature
OOR C
Distance traveled since DTC cleared
20998.00 KM
13050.34 Mile
EVAP system vapor pressure
OOR Pa
2.36 Psi
Barometric Pressure
96.00 kPa
Barometric Pressure
13.92 Psi
Oxygen sensor output current bank 1 sensor 1
0.06 mA
Oxygen sensor equivalence ratio bank 1 sensor 1
1.02
Air to fuel ratio from wide range oxygen sensor bank 1 sensor 1
15.01
Wide range oxygen sensor output current bank 2 sensor 1
0.05 mA
Wide range oxygen sensor equivalence ratio bank 2 sensor 1
1.01
Air to fuel ratio from wide range oxygen sensor bank 2 sensor 1
14.85
Catalyst Temperature Bank 1 Sensor 1
634.30 C
1173.92 F
Catalyst Temperature Bank 2 Sensor 1
634.30 C
1173.92 F
Control Module Voltage
13.84 V
Absolute load value
43.92 %
Commanded equivalence ratio
1.02
Relative throttle position
10.20 %
Ambient air temperature
28.00 C
82.40 F
Absolute Throttle Position B
34.51 %
Absolute pedal Position D
26.27 %
Absolute pedal position E
13.33 %
Commanded throttle acuator control
16.08 %
Quote
Pending DTCs
P2A04
Active DTCs
P2A04
Thats all you are looking for, looks like the O2 Sensor on "Bank 2, Sensor 2" which will be the downstream sensor is not functioning properly. It may need to be replaced, you can try clearing the code and see if it comes back.
But they are not too expensive on rockauto.
Your freeze frame indicates Bank 2 Sensor 2 is putting out 0 volts. If you've already verified it's plugged in, then it's not working. Or else there's a short in one of the wires, but it's far more likely to be the sensor.
Thanks for the information. I noticed the 0.0v as well as the 99% short term fuel trim readings. I am going to get under it tomorrow and try to find the sensor and check the wires. Hopefully it won't be one of those nearly impossible to get out!
I've read soaking in PB Blaster and/or heating up the bung with a small torch can help with the stuck in ones.
