Check your fluid level when hot and idling. I've changed trans fluid before, and measureed how much hot fluid I took out and replaced it with the same amount of room temp ATF. Turns out that ATF expands a lot when hot, so replacing the same volume with cooler fluid actually overfilled my tranny by .7 qts. I would not have even looked except that the trans began to make a strange, whinning sound not long after the fluid change. I checked the fluid level and was surprised to see it overfilled since I was so careful. I removed the excess fluid and the whine went away.
[ March 17, 2003, 06:06 PM: Message edited by: DEWFPO ]
