When I press the clutch on my Forester, occasionally there will be a squeak from the bellhousing.Seems to be right on the top where the slave pushes on the fork.
Would it be recommended to pull the slave off and lubricate it? What should I use for a lubricant? I was thinking high temperature silicone brake lube.
The slave itself is accessible from the top.
Thanks!
Thanks!
