The dealers higher labour rate, and the fact that VAG charges their dealers crazy prices for parts is why. I know some of the Audi flywheels are over £1000, you can buy the same part locally for £250.
Well, it depends. Maybe on this car, but if you are making any power or racing it 90,000 is pretty decent. You don't break stuff if you don't90,000 miles is early for a clutch failure. Has someone not familiar with how to drive a manual transmission been driving the car?
If not, it suggests a primary mechanical problem, something like your failure of the slave cylinder. It's not proof of course.
I would never use a SMF on a daily-driven car.IMO, but recommending another dual mass flywheel? That’s rather odd since it’s the major cause of clutch failures.
If the car is a keeper, OP will be in the same boat anywhere from 50-90k miles down the road.
Personally I would go with a regular flywheel on this one. Shift quality will suffer a bit, but the major failure point will be eliminated.
Never bothered me, but I’ve driven many crude machines in my life, so my standards are pretty low.I would never use a SMF on a daily-driven car.
Yeah I mean right now I'm daily-ing my '89 Trooper so comfort is pretty far down on my list of priorities.Never bothered me, but I’ve driven many crude machines in my life, so my standards are pretty low.![]()
What is that 6 hours book time ? So 3X overcharge on already expensive labour? Thieves !I'm really curious about the failure too but after chatting with the indy he doesn't believe the slave cylinder failed as he mentioned the clutch pedal should be on the floor if the slave went bad. Guessing like the flywheel its one of those 'replace while in there' things that the dealer quoted.
Dealer markup is nuts, I could understand a few hundred dollar difference but not $1800 difference.
My wife managed 240k on her 2005 Subaru Legacy GT wagon with 5mt and next owner was impressed with clutch in decent shape. The engine was a 250HP turbo flat 4 and car could do 0-60 under 7seconds.That’s a pretty standard life for a modern clutch on any semi performance vehicle. We used to do them on G37’s regularly at about 100k.
If it was an overspeed it will be logged.Well I think the mystery of the sudden clutch failure has come to light. Indy called today and the clutch "exploded" and it does need a new flywheel as well - well this seems to point to a money shift. Other half 'yeah i think that may have happened but it all happened so quick I didn't know what was going on'![]()
- thinks he may have gone from 6th to 3rd instead of 5th but even at legal freeway speeds I'm thinking that should still be somewhere south of redline.
I'm not asking anymore questions about the situation right now because the car is getting fixed and indy did not think any engine damage as no CEL and engine running normally - should be good to go with new clutch and flywheel (hopefully). This really has scared the hell out of the other half so I think it has been a valuable lesson. I really cannot judge as I did something similar in my '99 Neon ~20 years ago (5th to 2nd vs 4th) and it taught me the importance of being 100% certain what gear you are selecting. In my case it just destroyed the accessory belts and my car had enough 12v power to make it ~6 miles to the Dodge dealer who slapped two new belts on in under an hour for IIRC ~$80-90 and I was on my way.
Not sure if I even want a box of a broken apart clutch disc back. Might get it anyways and leave some pieces laying decoratively around the house as a reminder to always confirm your shift before you let the dang clutch out. I'm not that evil though so will probably just grab a picture for memories and toss it in the rubbish.
If you care to know.![]()
Is this the same person that starts the car cold and revs it to red line so the heat comes out quicker?
I try to be patient and educate
Technically, they aren't wrong.Is this the same person that starts the car cold and revs it to red line so the heat comes out quicker?
Yup - thats about what I have been doing. Just try to guide in the best direction and hope for the best.That's all you can do...I've learned it's just best to keep my mouth shut and inject some carefully worded suggestions when I can.
LOL this gave me a much needed laugh.Technically, they aren't wrong.
Eh, there are other issues associated with going to a SMF. I have never seen good results with it on some cars, like on the VQ37s. Lots of extra NVH and potential damage to the trans.Personally I would go with a regular flywheel on this one. Shift quality will suffer a bit, but the major failure point will be eliminated.
