Ford made 3-valve V8's in the mid 2000s with this stupid 2-piece spark plug design that is prone to breakage when you try to remove them. The ground is just a big loop over the center electrode, and unfortunately, they are only [platinum, not iridium, so they don't last as long as they could, and they're made by Autolite, which isn't the best. They were installed on F-series/F150/F250/Super Duty trucks, and another version on the Mustang and Explorer.
Champion makes a one-piece plug for these engines, but again, only platinum, not iridium, and they're even worse than the OE Autolites
Bosch, Denso, and NGK won't even touch these, and I can't blame them
But now, SKP has iridium spark plugs for these Fords. Iridium should last much longer than platinum, so you won't have to worry about broken spark plugs for a long time. If you're lucky, either the truck will rust before you have to replace them again, or better yet, real spark plugs will finally become available
While SKP isn't the best, they can't be worse than Autolite and Champion
So, has anybody here tried the SKP iridium on a 3V Ford?
Here is a picture:
Here is a picture:
