It has been shipped to ALS for analysis. Results should be in end of the week.
Singapore isn't China.Will be a mad rush to buy conventional gear oil from a Chinese co.
Been there many times - that’s a facility - I wrote Chinese co …Singapore isn't China.
As some one who lives in the region, singapore is a very car-unfriendly nation. There is a 10 year car approval permit to pay that is called COE that could cost 30,000 Singapore Dollars. It does not make sense for the general workers to own a car in singapore, hence you see those small motorcycles outside. The bosses and execs would own cars. If I was a singaporean, I woudnt own a car too. No way I am paying such a sum to the govt.
Looks like minimal to no contamination with <1 ppm Silicon and no other metals present. Very clean oil. Viscosity similar to a 40 grade engine oil. May I ask what this GL-5 is going into?
It's a VOA so to be expected, right? Just a forklift diff.Looks like minimal to no contamination with <1 ppm Silicon and no other metals present. Very clean oil. Viscosity similar to a 40 grade engine oil. May I ask what this GL-5 is going into?
Thanks for the info & yeah in theory, I just think about all the opportunities it can get contaminated along the way. From the blending process, taking the virgin oil sample, to the oil lab that may have prior contamination it's amazing how clean it shows up on the results. Ha!It's a VOA so to be expected, right? Just a forklift diff.
I assume you work in the oil industry?Will be a mad rush to buy conventional gear oil from a Chinese co.
what is that?I'd say it was a good thing to change being it only has 60 hrs on it.
OEM 80W-90 GL-5what is that?
I thought they were asking what is being serviced with that fluid, but I could be wrong here. Tractor?OEM 80W-90 GL-5
No not what was being serviced, what we were looking at, but thanks. It looks like a forklift of some kind.I thought they were asking what is being serviced with that fluid, but I could be wrong here. Tractor?
it looks pretty foamy, was it drained or did you suck it out?OEM 80W-90 GL-5
