Sinopec L-HM 32 Hydraulic Oil VOA
Central FL
Sent to ALS for analysis; results should be in by weeks end.
Interesting results here on this hydraulic fluid. Low TBN than an engine oil but that's probably expected for hydraulic fluids. How was your buying experience?
This is the best part, ridiculously easy and very quick shipping.
That's great to hear & my experience was just the Sinopec 15w40 from WalMart which went well too. I've called up that Sinopec website you listed several years back & they told me they had no idea how Walmart was able to sell it that cheap. Only downside is it's in & out of stock but I've been tracking it for years in my Walmart "Lists" so it's been fairly reliable overall.
Sorry, if this is the wrong thread.
I am wondering if I can use this oil for 27 ton Cub Cadet log splitter? Manual says I can use:
Shell Tellus® S2 M 32 Hydraulic Fluid,
Dexron® III/Mercon® automatic transmission fluid,
Pro-Select™ AW-32 Hydraulic Oil or
10WAW-ISO viscosity grade 32 hydraulic oil.
So would L-HM 32 Sinopec qualify as 10WAW-ISO viscosity grade 32 hydraulic oil?
This is a a AW32 hydraulic oil. So yes, if you go to their page here, it does cross reference to the Shell Tellus. I've been using the heck out of it in my forklift without issue. It's priced really well and shows up at your door.
