The Denso TT plug is a aftermarket port of the Super Ignition Plug that they invented for the Toyota D4-S engines. There’s probably no harm using them, they are identical to the OEM plug with an Ir center electrode and Pt disc/inlay on the ground strap. Just don’t gap them. A Camry I4 2AR-FE is child’s play for plugs. If it was the V6, stick with the OEM ones.
I’ve used the Platinum TT in a Subaru as well as a Honda GCV160 with no ill effects. 😉
