It probably was test run with a bit of oil in it, that was quickly but not completely drained prior to shipping. I've noticed that with other similar products, like my portable generator.
I also have a Simpson/Honda 3100 psi pressure washer, which has provided good service for a couple years so far, around the house. A couple of things to watch for: It's not super easy to start - have to release pump pressure after a couple of attempts, and the manual choke is just on/off. Also, be careful with the outlet hose connection to the pump, as the threads and hardware are cheap and wear prematurely. I am limping my original hose and pump along, but it's difficult to screw and unscrew that hose at this point. Finally, if you change the oil often you might want to plumb something on the oil drain...the two times I've changed the oil in my unit, it just spills all over the frame and garage floor. My lazy solution was a refill with some leftover Mobil 1 0W-40 and not changing the oil until I feel like I really have to...
