New Simpson 3100 psi Pressure Washer
Americus, GA
I was in need of a pressure washer. I found the Simpson at Tractor Supply. It came with one pint of Amsoil 10W30 OE oil. It was very simple to assemble. I just needed to add oil and attach the handle. I immediately removed the Torch spark plug and installed a NGK BPR6ES. It started on the first pull.
https://simpsoncleaning.com/products/megashot-ms61217-s-49-state/
Those Torch spark plugs crack me up.. I really don't know what to think of them. I have some spares that were included when buying some fuel parts for various OPE. I bought an Electric sprayer but I was sure glad to use a gas powered one when I power washed my basement walls & floor due to flooding over many years that I got under control.
Torch Plug tells me it's not a B & S engine LOL
Not for sale in California
2 year warranty is good
It's a CRX210 engine. Chinese or some other east Asian country of origin. The Torch plug went in the garbage. It should do all that I need.
I will need a thin wall 3/4" spark plug socket. The engine fins come very near to the plug.
I have a similar Simpson but with a Honda engine. Good unit, the hose that comes with it is garbage but other than that it should serve you well. Can't speak to that engine but I'm sure it's fine.
I'm glad that you told me about the hose. Can you tell me which hose that you bought as a replacement?
I wanted a 3/8" diameter that was longer and tougher for the long haul. Bought this one on Amazon and have been happy. Also a must on any pressure washer - quick connect couplings everywhere.
4000 PSI Grey 3/8" x 50 FT 1 Layers of High Tensile Wire Braided Rubber Wrapped Pressure Washer Hose with Couplers https://a.co/d/dGa6bvI
Thanks
